Op amp chip replacement
KAKU
12.10.2021, alle ore 11:13
I want to find an op-amp chip with the same internal structure as the 14-pin op-amp "LM3900". I read the LM2900 information?https://www.utmel.com/components/lm2900-operational-amplifie… It seems that LM2900 and LM3900 can be replaced with each other. Do you have any suggestions? I am using it for graduation design! Thanks!
gabe
12.10.2021, alle ore 14:20
are pretty much the same, looking quickly, if I don't miss anything, one is stronger in temperature than the other, after any data and identical, so I think it's the same thing, look here, if you see there are both in the tables:
https://www.ti.com/lit/ds/symlink/lm2900.pdf?ts=163404098805…
gabe
12.10.2021, alle ore 14:24
*any data is identical
KAKU
19.10.2021, alle ore 10:18
I see.
Thank u!
Gabe!
gabe
19.10.2021, alle ore 12:26
you're welcome, hope it was helpful to what you were looking for
