FORUM: Pic Micro
AIUTO MODIFICARE ASSEMBLER MASM
cavallo_leo
09.01.2021, alle ore 14:13
MI POTREBBE, PER FAVORE MODIFICARE IL PROGRMMA (ASSEMBLER MASM)
DELLA MIA STELLA DI NATALE DI MODO CHE LAMPEGGI PIU VELOCE.
IO NON SONO IN GRADO MASM DI FARLO... GRAZIE A TUTTI
VIDEO DELLA MIA STELLA: https://imgur.com/a/WweARMO
LINK: http://www.grix.it/viewer.php?page=8814
FILE MASM: http://www.grix.it/UserFiles/mard80/File/file%20parsic.r…
ASSEMBLER PROGRAMMA MASM:
; Source created with Parsic Version 3.x
; at : 03/11/2010 8.04.10
; Project File : C:\Documents and Settings\MARD\Desktop\stellla.pic
; Project Version : 1.0.30
; Created : 14/09/2010 21.06.00
; Last change : 03/11/2010 8.03.32
PROCESSOR 16F84A
INCLUDE P16F84A.INC
RADIX DEC
__IDLOCS H'0100'
__CONFIG _CP_OFF & _PWRTE_ON & _WDT_OFF & _XT_OSC
; Diverses
ZERO EQU Z ; ZERO-Flag
CARRY EQU C ; CARRY-Flag
; Variable
SYS_WSAV = 12 ; located in Bank 0, 1
SYS_SSAV = 13 ; located in Bank 0, 1
TR1 = 14 ; located in Bank 0, 1
TR1_HI = 15 ; located in Bank 0, 1
S2 = 16 ; located in Bank 0, 1
S0 = 17 ; located in Bank 0, 1
SYS_TMP1 = 18 ; located in Bank 0, 1
SYS_TMP2 = 19 ; located in Bank 0, 1
ZR1 = 20 ; located in Bank 0, 1
ZR1_FD = 21 ; located in Bank 0, 1
S1 = 22 ; located in Bank 0, 1
RAM = 23 ; located in Bank 0, 1
ERRORLEVEL -302 ; disable warning (Bankswitching)
ERRORLEVEL -306 ; disable warning (Pageswitching)
;Programmanfang
ORG 0
CLRF STATUS ; switch to RAM-Bank 0
GOTO SYS_INIT
NOP
NOP
;Interrupt-Adress
MOVWF SYS_WSAV ; save register
SWAPF STATUS,W
CLRF STATUS ; bank 0
MOVWF SYS_SSAV
BCF INTCON,T0IF ; Interrupt quitieren
INCFSZ TR1,F
GOTO SYS_INT_LABEL_0
INCF TR1_HI,F
SYS_INT_LABEL_0
EXITINT
SWAPF SYS_SSAV,W ; Register zurück
MOVWF STATUS
SWAPF SYS_WSAV,F
SWAPF SYS_WSAV,W
RETFIE
; Subroutines
; Direct jump into a table
SYSTABJMP
BCF INTCON,GIE
BTFSC INTCON,GIE
GOTO SYSTABJMP
MOVFW SYS_TMP2
MOVWF PCLATH
MOVFW SYS_TMP1
MOVWF PCL
;Initialisierung
SYS_INIT
MOVLW B'00100000'
MOVWF INTCON
; Set output before direction
BCF STATUS,RP0 ; Bank 0
MOVLW B'00000000'
MOVWF PORTA
MOVLW B'00000000'
MOVWF PORTB
MOVLW 15
BSF STATUS,RP0 ; Bank 1
MOVWF OPTION_REG
; Richtung setzen
MOVLW B'11110000'
MOVWF TRISA
MOVLW B'00000000'
MOVWF TRISB
; init vars
; Clear RAM
MOVLW 12
MOVWF FSR
CR1
CLRF INDF
INCF FSR,F
MOVFW FSR
SUBLW 80
BTFSS STATUS,ZERO
GOTO CR1
CLRF TMR0
BCF INTCON,T0IF
BSF INTCON,GIE ; Interrupt freigeben
;******* Haupt-Programm ***********
MAIN
; Timer -> TR1
MOVLW 19 ; Test auf >=
SUBWF TR1_HI,W ;F-W -> W
BTFSS STATUS,ZERO
GOTO LABEL_TR1_CHECK
MOVLW 19
SUBWF TR1,W ;F-W -> W
LABEL_TR1_CHECK
BTFSS STATUS,CARRY
GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
SUBWF TR1_HI,F ;F-W -> F
MOVLW 19
SUBWF TR1,F ;F-W -> F
BTFSS STATUS,CARRY
DECF TR1_HI,F
LABEL_TR1_SET ; toggel output
BTFSC S2,0
GOTO LABEL_TR1_CLR
BSF S2,0
GOTO LABEL_TR1_ENDE
LABEL_TR1_CLR
BCF S2,0
LABEL_TR1_ENDE
; Call subroutine NO
MOVLW LOW NO
MOVWF SYS_TMP1
MOVLW HIGH NO
MOVWF SYS_TMP2
MOVFW ZR1
ADDWF SYS_TMP1,F
BTFSC STATUS,CARRY
INCF SYS_TMP2,F
CALL SYSTABJMP
MOVWF S0
BSF INTCON,GIE
; Zähler -> ZR1
BTFSS S2,1 ; Reset ?
GOTO LABEL_ZR1_COUNT
CLRF ZR1
GOTO LABEL_ZR1_SETOUT
LABEL_ZR1_COUNT
; Test auf positive Flanke
BTFSC ZR1_FD,0
GOTO LABEL_ZR1_SETFD
BTFSS S2,0
INCF ZR1,F
LABEL_ZR1_SETOUT
LABEL_ZR1_SETFD
BTFSS S2,0
GOTO LABEL_ZR1_SETFD2
BSF ZR1_FD,0
GOTO LABEL_ZR1_END
LABEL_ZR1_SETFD2
BCF ZR1_FD,0
LABEL_ZR1_END
; Verteiler -> BV1
BTFSC S0,0
GOTO LABEL_BV1_0
BCF PORTB,0
GOTO LABEL_BV1_0_END
LABEL_BV1_0
BSF PORTB,0
LABEL_BV1_0_END
BTFSC S0,1
GOTO LABEL_BV1_1
BCF PORTB,1
GOTO LABEL_BV1_1_END
LABEL_BV1_1
BSF PORTB,1
LABEL_BV1_1_END
BTFSC S0,2
GOTO LABEL_BV1_2
BCF PORTB,2
GOTO LABEL_BV1_2_END
LABEL_BV1_2
BSF PORTB,2
LABEL_BV1_2_END
BTFSC S0,3
GOTO LABEL_BV1_3
BCF PORTB,3
GOTO LABEL_BV1_3_END
LABEL_BV1_3
BSF PORTB,3
LABEL_BV1_3_END
BTFSC S0,4
GOTO LABEL_BV1_4
BCF PORTB,4
GOTO LABEL_BV1_4_END
LABEL_BV1_4
BSF PORTB,4
LABEL_BV1_4_END
BTFSC S0,5
GOTO LABEL_BV1_5
BCF PORTB,5
GOTO LABEL_BV1_5_END
LABEL_BV1_5
BSF PORTB,5
LABEL_BV1_5_END
BTFSC S0,6
GOTO LABEL_BV1_6
BCF PORTB,6
GOTO LABEL_BV1_6_END
LABEL_BV1_6
BSF PORTB,6
LABEL_BV1_6_END
BTFSC S0,7
GOTO LABEL_BV1_7
BCF PORTB,7
GOTO LABEL_BV1_7_END
LABEL_BV1_7
BSF PORTB,7
LABEL_BV1_7_END
; Vergleich -> IF1
MOVFW ZR1
SUBLW 101 ; K - W -> W
LABEL_IF1_CHECK
BTFSC STATUS,CARRY ; Test auf -> <
GOTO LABEL_IF1_FALSE
LABEL_IF1_TRUE
BSF S2,1
GOTO LABEL_IF1_EXIT
LABEL_IF1_FALSE
BCF S2,1
LABEL_IF1_EXIT
; Verteiler -> BV2
BTFSC S1,0
GOTO LABEL_BV2_0
BCF PORTA,0
GOTO LABEL_BV2_0_END
LABEL_BV2_0
BSF PORTA,0
LABEL_BV2_0_END
BTFSC S1,1
GOTO LABEL_BV2_1
BCF PORTA,1
GOTO LABEL_BV2_1_END
LABEL_BV2_1
BSF PORTA,1
LABEL_BV2_1_END
BTFSC S1,2
GOTO LABEL_BV2_2
BCF PORTA,2
GOTO LABEL_BV2_2_END
LABEL_BV2_2
BSF PORTA,2
LABEL_BV2_2_END
BTFSC S1,3
GOTO LABEL_BV2_3
BCF PORTA,3
GOTO LABEL_BV2_3_END
LABEL_BV2_3
BSF PORTA,3
LABEL_BV2_3_END
; Call subroutine TAB
MOVLW LOW TAB
MOVWF SYS_TMP1
MOVLW HIGH TAB
MOVWF SYS_TMP2
MOVFW ZR1
ADDWF SYS_TMP1,F
BTFSC STATUS,CARRY
INCF SYS_TMP2,F
CALL SYSTABJMP
MOVWF S1
BSF INTCON,GIE
GOTO MAIN
; Table -> NO
NO
RETLW 255 ; // INDEX 0
RETLW 0 ; // INDEX 1
RETLW 255 ; // INDEX 2
RETLW 0 ; // INDEX 3
RETLW 255 ; // INDEX 4
RETLW 0 ; // INDEX 5
RETLW 1 ; // INDEX 6
RETLW 3 ; // INDEX 7
RETLW 7 ; // INDEX 8
RETLW 15 ; // INDEX 9
RETLW 31 ; // INDEX 10
RETLW 63 ; // INDEX 11
RETLW 127 ; // INDEX 12
RETLW 255 ; // INDEX 13
RETLW 255 ; // INDEX 14
RETLW 255 ; // INDEX 15
RETLW 255 ; // INDEX 16
RETLW 255 ; // INDEX 17
RETLW 0 ; // INDEX 18
RETLW 255 ; // INDEX 19
RETLW 0 ; // INDEX 20
RETLW 255 ; // INDEX 21
RETLW 0 ; // INDEX 22
RETLW 255 ; // INDEX 23
RETLW 0 ; // INDEX 24
RETLW 255 ; // INDEX 25
RETLW 255 ; // INDEX 26
RETLW 255 ; // INDEX 27
RETLW 255 ; // INDEX 28
RETLW 127 ; // INDEX 29
RETLW 63 ; // INDEX 30
RETLW 31 ; // INDEX 31
RETLW 15 ; // INDEX 32
RETLW 7 ; // INDEX 33
RETLW 3 ; // INDEX 34
RETLW 1 ; // INDEX 35
RETLW 0 ; // INDEX 36
RETLW 255 ; // INDEX 37
RETLW 0 ; // INDEX 38
RETLW 255 ; // INDEX 39
RETLW 0 ; // INDEX 40
RETLW 255 ; // INDEX 41
RETLW 0 ; // INDEX 42
RETLW 85 ; // INDEX 43
RETLW 170 ; // INDEX 44
RETLW 85 ; // INDEX 45
RETLW 170 ; // INDEX 46
RETLW 85 ; // INDEX 47
RETLW 170 ; // INDEX 48
RETLW 0 ; // INDEX 49
RETLW 255 ; // INDEX 50
RETLW 0 ; // INDEX 51
RETLW 255 ; // INDEX 52
RETLW 0 ; // INDEX 53
RETLW 255 ; // INDEX 54
RETLW 0 ; // INDEX 55
RETLW 254 ; // INDEX 56
RETLW 253 ; // INDEX 57
RETLW 251 ; // INDEX 58
RETLW 247 ; // INDEX 59
RETLW 239 ; // INDEX 60
RETLW 223 ; // INDEX 61
RETLW 191 ; // INDEX 62
RETLW 127 ; // INDEX 63
RETLW 255 ; // INDEX 64
RETLW 255 ; // INDEX 65
RETLW 255 ; // INDEX 66
RETLW 255 ; // INDEX 67
RETLW 254 ; // INDEX 68
RETLW 253 ; // INDEX 69
RETLW 251 ; // INDEX 70
RETLW 247 ; // INDEX 71
RETLW 239 ; // INDEX 72
RETLW 223 ; // INDEX 73
RETLW 191 ; // INDEX 74
RETLW 127 ; // INDEX 75
RETLW 255 ; // INDEX 76
RETLW 255 ; // INDEX 77
RETLW 255 ; // INDEX 78
RETLW 255 ; // INDEX 79
RETLW 0 ; // INDEX 80
RETLW 255 ; // INDEX 81
RETLW 0 ; // INDEX 82
RETLW 255 ; // INDEX 83
RETLW 0 ; // INDEX 84
RETLW 255 ; // INDEX 85
RETLW 0 ; // INDEX 86
RETLW 251 ; // INDEX 87
RETLW 247 ; // INDEX 88
RETLW 239 ; // INDEX 89
RETLW 223 ; // INDEX 90
RETLW 189 ; // INDEX 91
RETLW 123 ; // INDEX 92
RETLW 247 ; // INDEX 93
RETLW 239 ; // INDEX 94
RETLW 223 ; // INDEX 95
RETLW 191 ; // INDEX 96
RETLW 126 ; // INDEX 97
RETLW 253 ; // INDEX 98
RETLW 251 ; // INDEX 99
; Table -> TAB
TAB
RETLW 15 ; // INDEX 0
RETLW 15 ; // INDEX 2
RETLW 15 ; // INDEX 4
RETLW 0 ; // INDEX 6
RETLW 0 ; // INDEX 7
RETLW 0 ; // INDEX 9
RETLW 0 ; // INDEX 10
RETLW 0 ; // INDEX 11
RETLW 0 ; // INDEX 12
RETLW 0 ; // INDEX 13
RETLW 1 ; // INDEX 14
RETLW 3 ; // INDEX 15
RETLW 7 ; // INDEX 16
RETLW 15 ; // INDEX 17
RETLW 15 ; // INDEX 19
RETLW 15 ; // INDEX 21
RETLW 15 ; // INDEX 23
RETLW 7 ; // INDEX 25
RETLW 3 ; // INDEX 26
RETLW 1 ; // INDEX 27
RETLW 0 ; // INDEX 28
RETLW 0 ; // INDEX 29
RETLW 0 ; // INDEX 30
RETLW 0 ; // INDEX 31
RETLW 0 ; // INDEX 32
RETLW 0 ; // INDEX 33
RETLW 0 ; // INDEX 34
RETLW 0 ; // INDEX 35
RETLW 15 ; // INDEX 37
RETLW 15 ; // INDEX 39
RETLW 15 ; // INDEX 41
RETLW 5 ; // INDEX 43
RETLW 10 ; // INDEX 44
RETLW 5 ; // INDEX 45
RETLW 10 ; // INDEX 46
RETLW 5 ; // INDEX 47
RETLW 10 ; // INDEX 48
RETLW 15 ; // INDEX 50
RETLW 15 ; // INDEX 52
RETLW 15 ; // INDEX 54
RETLW 15 ; // INDEX 56
RETLW 15 ; // INDEX 57
RETLW 15 ; // INDEX 58
RETLW 15 ; // INDEX 59
RETLW 15 ; // INDEX 60
RETLW 15 ; // INDEX 61
RETLW 15 ; // INDEX 62
RETLW 15 ; // INDEX 63
RETLW 14 ; // INDEX 64
RETLW 13 ; // INDEX 65
RETLW 75 ; // INDEX 66
RETLW 71 ; // INDEX 67
RETLW 15 ; // INDEX 68
RETLW 15 ; // INDEX 69
RETLW 15 ; // INDEX 70
RETLW 15 ; // INDEX 71
RETLW 15 ; // INDEX 72
RETLW 15 ; // INDEX 73
RETLW 15 ; // INDEX 74
RETLW 15 ; // INDEX 75
RETLW 14 ; // INDEX 76
RETLW 13 ; // INDEX 77
RETLW 11 ; // INDEX 78
RETLW 7 ; // INDEX 79
RETLW 15 ; // INDEX 81
RETLW 15 ; // INDEX 83
RETLW 15 ; // INDEX 85
RETLW 14 ; // INDEX 87
RETLW 13 ; // INDEX 88
RETLW 11 ; // INDEX 89
RETLW 7 ; // INDEX 90
RETLW 15 ; // INDEX 91
RETLW 15 ; // INDEX 92
RETLW 14 ; // INDEX 93
RETLW 13 ; // INDEX 94
RETLW 11 ; // INDEX 95
RETLW 7 ; // INDEX 96
RETLW 15 ; // INDEX 97
RETLW 14 ; // INDEX 98
RETLW 13 ; // INDEX 99
END
cavallo_leo
09.01.2021, alle ore 14:14
UNA STELLA NATALIZIA COMANDATA DA UNA PIC 16F84A
gianmagna
09.01.2021, alle ore 14:56
se hai un quarzo da 8 Mhz lo metti al posto di quello da 4Mhz e già gira al doppio
Gianmagna
Aforisma di Albert Einstein
La teoria è quando si sa tutto e niente funziona. La pratica è quando tutto funziona e nessuno sa il perchè. Noi abbiamo messo insieme la teoria e la pratica: non c'è niente che funzioni... e nessuno sa il perchè
gianmagna
09.01.2021, alle ore 16:15
ciao Leo
ho ritrovato una vecchia versione del parsic proverò ,sempre se mi ricordo come
si fa, a mettere a 1500ms al posto dei 2500ms poi ti mando il file hex
Gianmagna
GioRock
09.01.2021, alle ore 17:12
Il codice da modificare è questo:
[CODE];***************************************************
; Timer -> TR1
BTFSS STATUS,ZERO
MOVLW 19
LABEL_TR1_CHECK
BTFSS STATUS,CARRY
GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
MOVLW 19
BTFSS STATUS,CARRY
DECF TR1_HI,F[CODE]
Bisogna diminuire MOVLW 19 per ridurre il tempo, tipo:
; Timer -> TR1
MOVLW 4 ; Test auf >=
BTFSS STATUS,ZERO
MOVLW 4
LABEL_TR1_CHECK
BTFSS STATUS,CARRY
GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
MOVLW 4
BTFSS STATUS,CARRY
DECF TR1_HI,F[/CODE]
Gio
GioRock
09.01.2021, alle ore 17:15
Non serve ne MASM per WINDOWS ne PARSIC, ma MPASM per PIC, qui il file HEX:
:020000040000FA
:1000000083011828000000008C00030E83018D007E
:100010000B118E0F0C288F0A0D0E83008C0E0C0E08
:1000200009008B138B1B112813088A001208820009
:1000300020308B00831200308500003086000F30A6
:1000400083168100F0308500003086000C3084007B
:100050008001840A0408503C031D28288312810172
:100060000B118B1701300F02031D382801300E02CF
:10007000031C452801308F0201308E02031C8F03C0
:1000800010184428101445281010B1309200003088
:100090009300140892070318930A112091008B17FC
:1000A000901C54289401592815185928101C5928B7
:1000B000940A101C5D2815145E2815101118632869
:1000C0008312061065288312061491186928861079
:1000D0006A28861411196E2806116F2806159119C1
:1000E0007328861174288615111A78280612792823
:1000F0000616911A7D2886127E288616111B8228E4
:10010000061383280617911B8728861388288617CD
:100110001408653C03188E2890148F289010161828
:1001200094288312051096288312051496189A288D
:1001300085109B28851416199F280511A0280515E0
:100140009619A4288511A52885151530920001302F
:100150009300140892070318930A112096008B1736
:100160003228FF340034FF340034FF3400340134CB
:10017000033407340F341F343F347F34FF34FF34EB
:10018000FF34FF34FF340034FF340034FF340034D4
:10019000FF340034FF34FF34FF34FF347F343F3406
:1001A0001F340F340734033401340034FF34003477
:1001B000FF340034FF3400345534AA345534AA34A3
:1001C0005534AA340034FF340034FF340034FF3493
:1001D0000034FE34FD34FB34F734EF34DF34BF3405
:1001E0007F34FF34FF34FF34FF34FE34FD34FB34FE
:1001F000F734EF34DF34BF347F34FF34FF34FF345F
:10020000FF340034FF340034FF340034FF34003452
:10021000FB34F734EF34DF34BD347B34F734EF3460
:10022000DF34BF347E34FD34FB340F3400340F34FC
:1002300000340F340034003400340034003400340F
:100240000034003400340134033407340F340034F4
:100250000F3400340F3400340F34003407340334C7
:1002600001340034003400340034003400340034ED
:10027000003400340F3400340F3400340F340034B1
:1002800005340A3405340A3405340A3400340F3492
:1002900000340F3400340F3400340F340F340F3473
:1002A0000F340F340F340F340F340E340D344B34FD
:1002B00047340F340F340F340F340F340F340F34EE
:1002C0000F340E340D340B34073400340F34003443
:1002D0000F3400340F3400340E340D340B34073433
:1002E0000F340F340E340D340B3407340F340E3406
:0202F0000D34CB
:0402F20000340034A0
:084000000000010000000000B7
:02400E00F13F80
:00000001FF
Gio
cavallo_leo
09.01.2021, alle ore 17:21
gianmagna:
ciao Leo
Io ho quarzo da 4mhz.. scambiare 8 mhz quale rischio??
cavallo_leo
09.01.2021, alle ore 17:22
cavallo_leo:
gianmagna:
ciao Leo
mi puo mandare email mich_zoff@alice.it
cavallo_leo
09.01.2021, alle ore 17:27
GioRock:
; Timer -> TR1
BTFSS STATUS,ZERO
MOVLW 19
LABEL_TR1_CHECK
BTFSS STATUS,CARRY
GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
MOVLW 19
BTFSS STATUS,CARRY
DECF TR1_HI,F[CODE]
; Timer -> TR1
BTFSS STATUS,ZERO
MOVLW 4
LABEL_TR1_CHECK
BTFSS STATUS,CARRY
GOTO LABEL_TR1_ENDE
LABEL_TR1_RESET
MOVLW 4
BTFSS STATUS,CARRY
GRAZ
GioRock:
[code]:020000040000FA
:0202F0000D34CB
:0402F20000340034A0
:02400E00F13F80
:00000001FF
GRAZIE, PROVERO'..
cavallo_leo
10.01.2021, alle ore 14:44
x GioRock
GRAZIE MOLTO, ADESSO FUNZIONA BENE, DOVE HAI TROVATO IL PROGRAMMA PER CONVERTIRE DA ASM A HEX ?
SALUTI
