FORUM: Pic Micro
Ho-avete risolto.
14.02.2023, alle ore 22:15
Ho-avete risolto.
 //Termometro, barometro, igrometro by Franco
#include <BME280I2C.h>
#include <Wire.h>
#include "U8glib.h"
#define SERIAL_BAUD 74880
BME280I2C bme;    // Default : forced mode, standby time = 1000 ms
                  // Oversampling = pressure Ã—1, temperature Ã—1, humidity Ã—1, filter off,
U8GLIB_ST7920_128X64 u8g(13, 11, 12, U8G_PIN_NONE);
   char pres_string[6];
   char temp_string[6]; //empty char array to hold the converted temp float
   char hum_string[6];  //empty char array to hold the converted humidity float
   float hum;
   float pres;
   float temp;
void setup()
  // Select font =================================================================
  u8g.setFont(u8g_font_8x13);
  u8g.setColorIndex(1);                   // Instructs the display to draw with a pixel on.
  Serial.begin(SERIAL_BAUD);
  while(!Serial) {} // Wait
  Wire.begin();
  while(!bme.begin())
    Serial.println("Could not find BME280 sensor!");
    delay(1000);
  switch(bme.chipModel())
     case BME280::ChipModel_BME280:
       Serial.println("Found BME280 sensor! Success.");
       break;
     case BME280::ChipModel_BMP280:
       Serial.println("Found BMP280 sensor! No Humidity available.");
       break;
     default:
       Serial.println("Found UNKNOWN sensor! Error!");
void loop()
   printBME280Data(&Serial);
  u8g.firstPage();
  do {
    draw();
  } while( u8g.nextPage() );
void printBME280Data
   Stream* client
   float temp(NAN), hum(NAN), pres(NAN);
   BME280::TempUnit tempUnit(BME280::TempUnit_Celsius);
   BME280::PresUnit presUnit(BME280::PresUnit_Pa);
   bme.read(pres, temp, hum, tempUnit, presUnit);
   unsigned char tempC = temp+0.01;
   unsigned char hum_float = hum+0.01;
   unsigned char pres_float = pres/100;
void draw(){
    u8g.drawFrame(0,0,128,21);            // upper frame
    u8g.drawFrame(0,21,128,21);           // middle frame
    u8g.drawFrame(0,42,128,21);           // lower frame
 // convert floats into char u8g strings
  u8g.drawStr( 5, 13, "Temp");       // do this for temperature
  dtostrf(temp, 3, 2, temp_string);
  u8g.drawStr(45,13, temp_string);
  u8g.drawStr(105,13, "*C");
  u8g.drawStr(5,35, "Um/r");             // do this for humidity
  dtostrf(hum, 3, 2, hum_string);
  u8g.drawStr(45,35, hum_string);
  u8g.drawStr(110,35, "%");
  u8g.drawStr(5,56, "Pres");             // do this for pressure
  dtostrf(pres/100, 4, 2, pres_string);
  u8g.drawStr(45,56, pres_string);
  u8g.drawStr(110,56, "mB");
  delay(10000);
Mi sono intestardito e alla fine ho risolto, grazie alle vostre segnalazioni,consigli, critiche e tutto il resto.
Con il codice allegato funziona e visualizzo tutti i dati, decimali compresi.
Magari ci faccio un articoletto, visto che tutti le ministazioni meteo che usano il BME280 visualizzano su display a caratteri basato su 44780.
Non che col grafico sia tanto diverso, ma almeno qualcosa di carino si fa.
Grazie ancora a tutti.
primok
15.02.2023, alle ore 08:47
A me sembra un copia incolla del sorgente che avevo postato io, allora non mi spiego perchè dicevi che non andasse. In tutti i modi le variabili globali
float hum;
float pres;
float temp;
sono superfle dato che sono ridichiarate all'interno delle funzioni draw() e printBME280Data.
Primok
15.02.2023, alle ore 10:23
Ho capito una cosa, che se il compilatore va a buon fine non è detto che funzioni come dovrebbe.
Considera che nello sketch postato i tre comandi unsigned ci sono, ma se li tolgo va lo stesso.
Visualizzo i dati corretti, o almeno gli stessi che ho in diagnostica.
Quando ho testato integralmente il tuo sketch avevo, come detto , nessun valore visualizzato a schermo arduino.
Praticamente ho copiato in void () draw
Con questo va, ho solo aggiunto un /100 alla variabile pres che essendo in hPa era appunto 100 volte più grande.
Grazie sempre.
primok
15.02.2023, alle ore 12:21
Se ti riferisci a:
questi non sono comandi ma dichiarazione di variabili di tipo char inizializzate
rispettivamente a
a temp+0.01
hum+0.01;
pres/100;
oltretutto sbagliate perché assegni a variabili di tipo unsigned char valori di tipo float.
Va lo stesso perché non sono usate da nessuna parte ed il compilatore di arduino è un pò troppo permissivo ma dovrebbe segnalarti quantomeno un warming.
Il valore #define SERIAL_BAUD 74880 per il baudrate da dove viene fuori?
Saluti
15.02.2023, alle ore 16:02
Quello è il risultato della foga e/o entusiasmo.
Il serial mi serviva per verificare le variabili in monitor.
Appena funzionato ho alleggerito il codice che succhiava parecchie risorse e l'ho copincollato sul forum.
Poi ho eliminato gli unsigned e il resto che non serviva.
Grazie.
