About building a device that uses Arduino uno to draw accelerometer data from 9-axis motion shielding on a 1.8 "TFT display
Autore
Messaggio
opzioni
polooo
postato il: 26.03.2022, alle ore 14:57
I wonder if embrio can help me solve my problem. I have little programming experience. I'm trying to build a device that uses Arduino uno to draw accelerometer data from 9-axis motion shielding on a 1.8 "TFT display. I want to draw the data as close to real time as possible.
I found three sample programs that I think contain everything needed to do all this. I lack the expertise to correctly combine them
? TFT graphic test
Simulation diagram
9-axis shield sample: accelerometer
From the accelerometer example, I only need one axis to draw the graph. I was thinking that I could replace the potentiometer voltage in the TFT graphic example with this data.
Thank you very much for any help.
Thank you!:)
