nicolacantalupo:
[CUT] Il suono non è pulito e sono presenti riverberi[CUT]
hai gia' provato i suggerimenti delle FAQ?
https://wolicheng.com/womic/faq.html
Q:There is serious noise like static current. How to avoid it?
A: Some audio source may be too sensitive to environment noise. Please go to app settings, select different MIC device as audio source and check which is the right one.
Q:The sound is robotic. How to solve it?
A:This may be caused by different reasons. Here are some tips for your reference:
1) Put WO Mic app into foreground. Android will always give high priority to foreground app to run.
2) Close other apps which may consume too much CPU. WO Mic needs enough CPU duty to do audio packet encoding and transmission.
3) Bluetotoh and Wifi are both using 2.4G ISM frequency. They may interference each other seriously. If it's allowed, while you are using one wireless, you better shut down the other. Please do this on both phone and PC.
Considera anche i vari moduli connessi all'interno del PC: client, driver, virtual device, mixer audio, basta che uno sia rallentato o che non lavori alla massima priorita' ...
