Ci riprovo... sostituite le doppie virgolette con due virgolette semplici...
File originale in C che utilizza il modulo di comparazione del PIC:
#define _XTAL_FREQ 20000000 // set crystal oscillator to 20MHz.
#define TMR1PRESCALE 8 // timer1 prescaler is 8.
#define OUT RC2 // use the name OUT for RC2 pin.
#include <xc.h>
// BEGIN CONFIG
#pragma config FOSC = HS // Oscillator Selection bits (HS oscillator)
#pragma config WDTE = OFF // Watchdog Timer Enable bit (WDT enabled)
#pragma config PWRTE = OFF // Power-up Timer Enable bit (PWRT disabled)
#pragma config BOREN = ON // Brown-out Reset Enable bit (BOR enabled)
#pragma config LVP = OFF // Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit (RB3 is digital I/O, HV on MCLR must be used for programming)
#pragma config CPD = OFF // Data EEPROM Memory Code Protection bit (Data EEPROM code protection off)
#pragma config WRT = OFF // Flash Program Memory Write Enable bits (Write protection off; all program memory may be written to by EECON control)
#pragma config CP = OFF // Flash Program Memory Code Protection bit (Code protection off)
//END CONFIG
// variables and constants declarations
unsigned long CCPR = 0; // holds the value needed to be put in CCP's registers.
unsigned long current_period = 0; // holds the period that timer1 will use.
const unsigned long total_period = 12500; // 20ms for 50hz frequency.
// interrupt service routine
void interrupt tmr1isr () {
if (CCP1IF == 1) { // if CCP compare interrupt flag is set
if ((current_period > 0) && (current_period < total_period)){ // if duty is > 0% AND < 100% then:
if (OUT == 1) { // if the output was 1 -> was 'on-time'.
OUT = 0; // set output to 0 in order to achieve 'off-tim'.
CCPR = total_period - current_period; // make it time for 'off-tim', off-time = full time - on time.
else { // if the output was 0 -> was 'off-time'.
OUT = 1; // set output to 1 in order to achieve 'on-time' CCPR = current_period; // make it time for 'on-time'.
else {
if (current_period == total_period) { OUT = 1;} // if duty = 100%, then output 1 all the time.
if (current_period == 0) {OUT = 0;} // if duty = 0%, then output 0 all the time.
// now set the value of CCPR into CCP module's registers:
CCPR1H = CCPR >> 8; // right-shift CCPR by 8 then load it into CCPR1H register (load higher byte).
CCPR1L = CCPR; // put the lower byte of CCPR in CCPR1L register.
CCP1IF = 0; // reset CCP1 interrupt flag.
// main function:
void main() {
TRISC = 0; // port c is output.
PORTC = 0; // port c = 0.
T1CON = 0b00110000; // timer1 uses prescaler value of 8 and it is off.
TMR1H = 0; // timer1 registers have 0 (clear).
TMR1L = 0;
CCP1CON = 0x0b; // set CCP module to compare mode and trigger special event when interrupt happens.
CCPR = 0; // load 0 in CCPR.
CCP1IF = 0; // clear CCP1 interrupt flag.
CCP1IE = 1; // enable CCP1 interrupt.
INTCON = 0xC0; // enable global and peripheral interrupt.
T1CON = 0b00110001; // start timer1 with the same settings like before.
while (1) { // infinite loop.
// TEST CODE...
current_period = total_period * 0.5; // 50% duty cycle.
__delay_ms(2000); // delay 2s.
current_period = total_period * 0.1; // 10% duty cycle.
current_period = total_period * 1; // 100% duty cycle.
current_period = total_period * 0; // 0% duty cycle.
Ho convertito in basic la parte dell'interrupt:
'if CCP1IF_bit=1 then ' pir1.2=1 then ' CCP1IF_bit=1 then
' if (current_period>0) and (current_period<total_period) then
' if OUT=1 then
' OUT=0
' CCPR=total_period - current_period
' else
' OUT=1
' CCPR=current_period
' end if
' else
' if (current_period=total_period) then
' OUT=1
' end if
' if current_period=0 then
' OUT=0
' end if
' end if
' CCPR1H=CCPR>>8
' CCPR1L=CCPR
' CCP1IF_bit=0 ' pir1.2=0
'end if
Essendo molto nidificato (quello in C) non so se ho convertito bene... forse il problema è li.
Naturalmente ho inserito anche la parte di INIT:
'T1CON=%00110001 '00110000
'TMR1H=0
'TMR1L=0
'CCP1CON=%00001011 '0x0b
'CCPR=0
'pir1.2=0 'CCP1IF=0
'pie1.2=1 'CCP1IE=1
'INTCON=%00110001
total_period=12500
CCPR=0
current_period=0
e la parte MAIN in un ciclo while:
current_period=total_period/2
pausa_ms(2000)
current_period=total_period/10
pausa_ms(2000)
current_period=total_period*1
pausa_ms(2000)
current_period=total_period*0
pausa_ms(2000)
non va....
