lorebaro
postato il: 23.06.2020, alle ore 16:12 |
Ciao MB54,
ho provato e funziona, io sto usando la rete wifi.
questo è il mio file dhcpcd.conf
# A sample configuration for dhcpcd.
# See dhcpcd.conf(5) for details.
# Allow users of this group to interact with dhcpcd via the control socket.
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
# Some non-RFC compliant DHCP servers do not reply with this set.
# In this case, comment out duid and enable clientid above.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
option domain_name_servers, domain_name, domain_search, host_name
option classless_static_routes
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU. This is applied to DHCP routes.
option interface_mtu
# A ServerID is required by RFC2131.
require dhcp_server_identifier
# Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
# Example static IP configuration:
#interface eth0
#static ip_address=192.168.0.10/24
#static ip6_address=fd51:42f8:caae:d92e::ff/64
#static routers=192.168.0.1
#static domain_name_servers=192.168.0.1 8.8.8.8 fd51:42f8:caae:d92e::1
# It is possible to fall back to a static IP if DHCP fails:
# define static profile
#profile static_eth0
#static ip_address=192.168.1.23/24
#static routers=192.168.1.1
#static domain_name_servers=192.168.1.1
# fallback to static profile on eth0
#interface eth0
#fallback static_eth0
interface wlan0
static ip_address=192.168.1.213/24
static domain_name_servers=192.168.1.1 8.8.8.8
io ho modificato wlan0 che è la wifi.
Guarda se la tua rete ha un altro nome, il comando ifconfig ti fa vedere le interfacce di rete.
Lorenzo
Lorenzo
postato il: 23.06.2020, alle ore 16:30 |
Nell' ultima prova devo aver cancellato tutto il contenuto del file. Lo recupero e poi provo ancora.
Direi che il mio era del tutto uguale al tuo; forse però il mio dhcp server non ha un ID, come richiesto dall' istruzione
però l' IP dinamico che rilascia viene accettato.
Il dhcp server è un servizio di un NAS, che è l' unico hw raggiungibile ovunque nella rete.
Come hai fatto a fare copiaincolla del contenuto del file? Con putty non ci riesco. |
lorebaro
postato il: 23.06.2020, alle ore 16:59 |
Ciao MB54,
MB54: Nell' ultima prova devo aver cancellato tutto il contenuto del file. Lo recupero e poi provo ancora.
Quella parte serve per avere un indirizzo dal DHCP.
Se vuoi un indirizzo fisso, non serve, potrebbe anche non esserci un DHCP.
Per prendere il file ho usati WinSCP. Ti permette di entrare in un dispositivo linux e lavorare con il file system.
Attenzione ai diritti.
Lorenzo |
postato il: 23.06.2020, alle ore 19:02 |
Avevo scaricato settimane fa l' immagine della versione 1.3.12 Ieri, appena installato mi ha chiesto di aggiornare alla 1.4: ed ho avuto i problemi di cui ho scritto.
Poco fa ho rimontato la 1.3.12 L' IP statico funziona, in compenso non mi ha piu visto il dns di google 8.8.8.8.
static domain_name_servers= 192.168.69.1 8.8.8.8
Il test di connessione fatto a 8.8.8.8 fallisce; funziona con il dns interno, ma in compenso non mi dice più nulla di eventuali aggiornamenti (prima era estremamente loquace) e anche chiedendo di aggiornare non fa nulla
Ho rimesso l' IP dinamico e continua a non vedere il dns di google.
Devo fare un break e valutare tutte le variabili: direi che con WinSCP è estremamente piu' comodo che con monta/smonta SD e Putty.
Prendo un poco di pausa e cerco di ripartire con una nuova installazione pulita. Ho riavviato tutta l' infrastruttura di rete: nulla cambia
postato il: 23.06.2020, alle ore 20:04 |
Rifatto tutto ex novo sul pulito.
L' immagine scaricata è la 2019-09-26-octopi-buster-lite-0.17.0.img
inserita nello zip octopi-buster-lite-0.17.0.zip
Ricaricata con Balena Etcher su SD: viene installata la versione 1.3.12; risultato:
IP dinamico funziona
IP statico funziona
in entrambe i casi viene visto il DNS esterno di Google e viene verificata la presenza di aggiornamenti.
Aggiornato Octoprint alla versione 1.4.0;
risultato:
IP statico funziona
in entrambe i casi viene visto il DNS esterno di Google e viene verificata la presenza di aggiornamenti (che al momento ovviamente non ci sono).
Problema risolto, non è chiaro quale fosse l' origine del problema, ma adesso la connettività wifi funziona correttamente.
Grazie per il supporto; non ti rilassare perchè bisogna attaccarci la telecamera ed ho già visto che ci sono problemi. Prima provo, se non funziona confido in te.
lorebaro
postato il: 23.06.2020, alle ore 23:22 |
MB54, ma devo aver timore?
Scherzo.
Lorenzo |
postato il: 24.06.2020, alle ore 11:39 |
MB54: ,,non ti rilassare perchè bisogna attaccarci la telecamera ed ho già visto che ci sono problemi...
I problemi, come previsto, ci sono. Cosa non grave, perchè posso benissimo usare la telecamera separatamente da Octoprint.
La telecamera IP WiFi è una Reolink E1 Zoom
https://reolink.com/product/e1-zoom/
con queste porte:
media 9000
http 80
https 443
rtsp 554
rtmp 1935
onvif 8000
opz. uid 952700015P3VR3I7
Prevede un' APP per il controllo Android ed un programmino per il controllo da Pc: con ambedue la configurabilità è limitata, ma ho visto che è incrementabile raggiungendo la camera direttamente da browser
http://192.168.69.48/?action=stream
http://utente:psw@192.168.69.48/?action=stream
Ho provato anche con VLC e lo stream viene visto
rtsp://utente:psw@192.168.69.48:554//h264Preview_01_main
Ho visto questa pagina di chiarimento sul forum di octoprint
https://docs.octoprint.org/en/master/configuration/config_ya…
e questa discussione
https://community.octoprint.org/t/configuration-of-a-wifi-ca…
Nulla da fare; Octoprint non visualizza lo stream della mia camera
Consigli?
lorebaro
postato il: 24.06.2020, alle ore 12:53 |
Ciao MB54,
c'è qualcosa che non capisco, se usi una camera ip, perchè la vuoi far passare sul raspberry, accedi direttamente ad essa, fai prima.
Nelle discussioni postate un utente mi sembra che abbia risolto con una webcam specifica.
Octoprint è fatto per usare una webcam Usb o il modulo cam del raspberry.
Li non hai problemi.
Lorenzo
postato il: 24.06.2020, alle ore 13:59 |
lorebaro: .. se usi una camera ip, perchè la vuoi far passare sul raspberry, accedi direttamente ad essa, fai prima.
Vero. ed infatti avevo scritto
MB54: ... posso benissimo usare la telecamera separatamente da Octoprint.
Il vantaggio a cui avevo pensato era quello di avere un'unica interfaccia. Ho visto che in Octoprint sono state testate alcune fotocamere IP Wifi, per cui ho provato.
